Solar Power Converter
Solar Panels Technician
Sunsynk® has produced a hybrid inverter specifically designed to handle solar systems that power heaters, water pumps fitted hot tubs, greenhouses and similar applications.
The inverter is perfect for heating your water on sunny days using power generated by the solar array, and on those days with inclement weather, the power can be taken alternatively from the mains grid.
SUN-3K-G
  • Max DC Input Power - 3.6kW
  • Max DC Input Voltage - 550V
  • Start-up DC Input Voltage - 80V
  • MPPT Operating Range - 70~550V
  • Max DC Input Current - 12.5A
  • Number of MPPT / String per MPPT - 1/1
  • Rated Output Power - 3kW
  • Max Active Power - 3.3kW
  • Rated AC Grid Voltage - 230V
  • AC Grid Voltage Range - 160~300V
  • Rated Grid Frequency - 50/60Hz
  • Operating Phase - Single-Phase
  • Rated AC Grid Output Current - 13.1A
  • Max AC Output Current - 14A
  • Output Power Factor - 0.8 leading to 0.8 lagging
  • Grid Current THD - <2%
  • DC Injection - 13.1A
  • Grid Frequency Range - 47~52 or 57~62
  • Size (W x H x D) - 330 x 310 x 115mm
  • Weight - 6kg
  • Internal Consumption - <1W (Night)
  • Running Temperature - -25°C-65°C
  • Ingress Protection - IP65
  • Noise Emission - <25dB
  • Cooling Concept - Natural Cooling
  • Max Operating Altitude - 2000m
  • Designed Lifetime - >20 Years
  • Operating Surroundings Humidity - 0-100%
Output
General Data
SUN-5K-G
  • Max DC Input Power - 6.5kW
  • Max DC Input Current - 12.5A + 12.5A
  • Number of MPPT / String per MPPT - 2/1
  • Rated Output Power - 5kW
  • Max Active Power - 5.5kW
  • AC Grid Voltage Range - 180~300V
  • Rated AC Grid Output Current - 21.7A
  • Max AC Output Current - 23.9A
  • Size (W x H x D) - 330 x 310 x 172mm
  • Weight - 11kg
Output
General Data
Protection
  • DC Reverse-Polarity Protection - Yes
  • AC Short Circuit Protection - Yes
  • AC Output Over-current Protection - Yes
  • Output Over-voltage Protection - Yes
  • Insulation Resistance Protection - Yes
  • Ground Fault Monitoring - Yes
  • Islanding Protection - Yes
  • Temperature Protection - Yes
  • Integrated DC Switch - Yes
  • Remote software upload - Yes
  • Remote change of operating parameters - Yes
  • Surge protection - DC Type II / AC Type II
  • Display - LCD1602
  • Interface - RS485/RS232/Wi-Fi/LAN
Features
  • DC Connection - MC-4 mateable
  • AC Connection - IP65 rated plug
Efficiency
  • Max. Efficiency - 97.5%
  • Euro Efficiency - 97.3%
  • MPPT Efficiency - >99%
