Sunsynk L5.1 Battery
The perfect solar storage solution.
The Sunsynk L5.1 Battery is a high-performance battery that provides reliable power for a range of equipment. It is designed to be used in high power scenarios and its compact size makes it ideal for use in limited spaces. With its long cycle life, the Sunsynk L5.1 Battery is a durable and cost-effective choice for those who need uninterrupted power supply.
The Sunsynk L5.1 is a high-capacity lithium ion battery with a built-in BMS for maximum safety and longevity. With 5.12kWh capacity and parallelable technology, you can easily upgrade your power supply as your needs change. Its advanced cell balancing technology ensures that each cell is charged and discharged evenly, extending the life of the battery. Order yours today for a reliable and sustainable energy source.
5.12kWh
L-Series Battery
SUNSYNK-L5.1
Don't forget to fully charge your batteries upon installation.
.png)
