Our Products
Solar Operations
Battery Storage
Solutions
Meet our Parallelable Hybrid Parity Inverter
Storage Inverter Features
Programmable export.
Can parallel on or off grid.
Single or Three phase.
Works with wind turbines.
Works with micro inverters.
Smart load.
AGM or lithium batteries.
50% surge current for 10 sec.
Power Management
A highly efficient power management tool that allows the user to hit those 'Parity' targets by managing power coming from multiple sources such as solar, mains grid and power generator and then effectively storing and releasing electric power as the utilities require.
The inverter has many uses and is recommended for the following applications:
Marine (vessel power management)
Power shedding (home/office/factory)
UPS (uninterruptible power supply)
Remote locations with solar and wind generators
Building sites
Military locations
Telecommunication sites
For more information contact sales@sunsynk.com
Inverters
3.6kW Hybrid Inverter
Reduce your electricity costs by managing power from various energy sources.
5.5kW Hybrid Inverter
An inverter thats is great for the average home.
8.8kW Hybrid Inverter
An inverter thats is great for expanding homes or businesses.
16kW Hybrid Inverter
The Sunsynk MAX
3.6kW Ecco
Hybrid Inverter
An inverter that is suitable for
residential use.
5.5kW Ecco
Hybrid Inverter
residential use.
8.8kW Ecco
Hybrid Inverter
users to hit those 'parity' targets.
3-Phase 8kW
Hybrid Inverter
management tool for
three-phase grid applications.
3-Phase 10kW
Hybrid Inverter
Allows the user to control
power flow from multiple sources.
3-Phase 12kW
Hybrid Inverter
An inverter that can operate and
balance the load.
Micro Inverter
Perfect for new-build houses where the customer needs a
simple solar system.
Batteries
Sunsynk REPT
5.32kWh Battery
IP20.
Sunsynk L-Series 3.07kWh Battery
IP65 LiFePO4.
Sunsynk L-Series 5.12kWh Battery
IP65 LiFePO4.
Sunsynk L-Series 5.32kWh Battery
IP65 LiFePO4.
Sunsynk G-Series 5.32kWh Battery
IP20 LiFePO4.
Sunsynk W-Series 5.32kWh Battery
IP65 LiFePO4.
Sunsynk W-Series 10.65kWh Battery
IP65 LiFePO4.
High Voltage
High Voltage
Series
LiFePO4.
3-Phase 50kW
Hybrid Inverter
A highly efficient power management tool.
