7kW Ecco Hybrid Inverter
A highly efficient power management tool that allows the user to hit those 'parity' targets.
The Sunsynk Hybrid Parity Inverter is a highly efficient power management tool that allows the user to hit those ‘parity’ targets by managing power flow from multiple sources such as solar, wind turbines, main electrical grids, and generators, and then effectively storing and releasing electric power as the utilities require.
It also carries a weatherproofing rating of IP65 and is fitted with two MPPT ports. Its convenient LCD display offers the user a configurable and accessible button operation, and once the Wi-Fi dongle has been attached, the user can monitor and adjust the inverter’s functions remotely to make the most of installed power generation and storage.
The 7kW Ecco hybrid inverter is ideal when you need a bit more power, especially for systems that are totally off-grid or where a substantial UPS is required. It has a 50% power surge facility and the advantage that it can reverse and charge batteries with very high power when required. In addition, since Sunsynk Hybrid Inverters use IGBT, they are more reliable and can guard your system against surges and EMF.
SUNSYNK-7K-SG05LP1
Features:
Overload / temperature / short-circuit protection.
Supports Wi-Fi monitoring.
3-stage MPPT charging for optimal battery performance.
Timing adjustable for convenient and efficient operation.
On-grid, off-grid or uninterrupted power supply (UPS).
Fan cooling - IP65 protection.
Warranty included.
