5.5kW Hybrid Inverter
Reduce your electricity costs by managing power from various energy sources.
Reduce your electricity costs by managing power from various energy sources, including solar panels, batteries, the national electricity grid, a generator or even a wind turbine – all with a Sunsynk Hybrid Inverter. It’s ideal for home and business and scalable so that you can expand it as required.
5.5kW
Hybrid Inverter
SUNSYNK-5K-SG03LP1
5.5kW Ecco
Hybrid Inverter
SYNK-5K-SG04LP1
• Start with UPS backup power (with batteries and inverter only) and add panels later.
• Start with Grid-tied (with panels and inverter only) and add batteries later.
• Install a complete Hybrid system including batteries and solar panels which can be
expanded, or...
• Go totally off the grid with a completely independent system.
Ideal for powering TVs, decoders, computer equipment and appliances that consume more energy such as fridges, microwaves, washing machines, dishwashers, kettles and toasters.
Inputs:
PV solar
AC grid power
Batteries
Generator
Output voltage –
220/230/240Vac
Continuous power
5000W
Backup power - 5000W
DC – 48V
Battery charger – 120A
Transfer time <= 10ms
Battery charger adjustable for battery bank size and type
Can charge Lead Acid and Li-ion batteries
Li-ion battery charging self-adapts to BMS
Solar Input
Max power input – 6500W
Max V DC input – 370V (100V~500V)
Max current input – 13A + 13A
MPPTs – 2
MPPT Range – 125~425V
Multi-core processor design and advanced MPPT control
High reliability and response speed
Programmable export
Works parallel on or off-grid
Single-phase operation
Multiple operating modes:
Grid-tie only
Hybrid
Off-grid
Battery only
Additional features
AC couple – For additional PV input
6 stages time of use settings
IP65
Meter Port (Ecco model only)
