3.6 / 5kW Ecco Hybrid Inverter
Suitable for residential and light commercial use
The 3.6kW and 5kW Sunsynk Ecco Hybrid Inverter is suitable for residential and light commercial use,
maximising the self-consumption rate of solar energy and increasing your energy impedance.
During the day, the PV system generates electricity which will be provided to the loads initially. Then, the excess energy will charge the battery via the inverter.
Finally, the stored energy can be released when the loads require it.
The battery can also be charged by the diesel generator to ensure uninterrupted supply in the event of a grid blackout. It is equipped with a RS485/CAN port for battery communication.
Features:
Colourful touch LCD, IP65 protection degree.
DC couple and AC couple to retrofit existing solar system.
Max. 16 inverters in parallel; support multiple batteries parallel.
Max. charging / discharging current of 120A.
6 time periods for battery charging / discharging.
Support storing energy from diesel generators.
Warranty included.
